CAT INTERFACE ERROR IN THE CLUSTER
hl1bru
Post by hl1bru »
There is a bug in the cluster.
Clicking on a spot information in the cluster, starts the CAT to change its freq and mode to the connected RIG.
The problem is the mode changes reversed way.
For example, clicking LSB(Below 7MHz) then changes to USB
Clicking USB(upper 10MHz) then changes to LSB.
I am using IC7600 and OMNIRIG interfaces
Thank you,
Henry
DE HL1BRU
Re: CAT INTERFACE ERROR IN THE CLUSTER
If you search this forum you will find this question has been asked a few time before.
The answer is to adjust the settings in the Log4OM/settings/Program configuration/CAT menu where you can reverse the modes for Icom and Elecraft abnormalities
