CAT INTERFACE ERROR IN THE CLUSTER
Posted: 08 Jun 2020, 14:09
There is a bug in the cluster.
Clicking on a spot information in the cluster, starts the CAT to change its freq and mode to the connected RIG.
The problem is the mode changes reversed way.
For example, clicking LSB(Below 7MHz) then changes to USB
Clicking USB(upper 10MHz) then changes to LSB.
I am using IC7600 and OMNIRIG interfaces
Thank you,
Henry
DE HL1BRU
Thank you,
Henry
DE HL1BRU
