Page 1 of 2
probleme avec 2.7.0.0
Posted: 08 Jun 2020, 18:55
by F1TRF
bonjour
je viens d'installé la derniere version et je me retrouve face a un probleme
les qsl se mettent sur NO, alors que dans la configuration, tout est sur REQUEST
merci
Re: probleme avec 2.7.0.0
Posted: 12 Jun 2020, 10:53
by F4GJC
Bonjour,
Pourriez-vous insérer des copies d’écran du problème dans le POST?
Merci.
73 Christian
Posted: 12 Jun 2020, 11:14
by DF5WW
Command for insert Image hasn´t worked. I have made screenshots from source and attached it with
direct attachment upload to the server. Please use Screenshots and use the attachment facility to
upload and inserting it next time.
Posted: 12 Jun 2020, 16:27
by F4GJC
Bonjour,
Pourriez-vous :
* m'indiquer si vous utilisez la version installable ou portable de Log4om ?
* contrôler et/ou m'envoyer le fichier de configuration de Log4Om ? config.json
Le paramètre à identifier est la section suivante : DefaultConfirmations
Attention, le fichier de configuration contient les comptes et les mots de passe pour accéder aux services extérieurs : Eqsl, Lotw etc.
Merci de les supprimer si vous souhaitez m'envoyer le fichier pour que j'analyse le problème.
Christian
Posted: 13 Jun 2020, 18:25
by F1TRF
bonjour
en attendant j'ai remis la version 2.6.1.0 et tout remarche correctement.
version installable
*.json de la v2.6.1.0
"DefaultConfirmations": [
"CT": "LOTW",
"S": "Requested",
"R": "Requested",
"SV": "Electronic",
"RV": "Electronic"
"CT": "EQSL",
"S": "Requested",
"R": "Requested",
"SV": "Electronic",
"RV": "Electronic"
"CT": "QSL",
"S": "No",
"R": "Requested",
"SV": "Electronic",
"RV": "Electronic"
"CT": "QRZCOM",
"S": "Requested",
"R": "Requested",
"SV": "Electronic",
"RV": "Electronic"
"CT": "HRDLOG",
"S": "Requested",
"R": "Requested",
"SV": "Electronic",
"RV": "Electronic"
"CT": "HAMQTH",
"S": "No",
"R": "No",
"SV": "Electronic",
"RV": "Electronic"
"CT": "CLUBLOG",
"S": "No",
"R": "No",
"SV": "Electronic",
"RV": "Electronic"
"CT": "CUSTOM",
"S": "No",
"R": "No",
"SV": "Electronic",
"RV": "Electronic"
je réinstalle la v2.7.0.0 et je vous envoi ça dès que possible.
merci
73 Laurent
Posted: 13 Jun 2020, 19:38
by F1TRF
j'ai remis la version 2.7.0.0 et le probleme est revenu
fichier .json identique a celui de la v2.6.1.0
merci
Posted: 14 Jun 2020, 09:38
by F4GJC
Bonjour Laurent,
Le ficher config.json est le fichier de configuration qui contient l'ensemble des paramètres de configuration du logiciel Log4OM.
Il est mis à jour avec les paramètres des nouvelles fonctionnalités à chaque montée de version du logiciel.
Pourriez-vous faire le test suivant :
Ouvrir Log4OM > Settings > Program Configuration > Confirmations
Procéder aux réglages comme indiqué dans la capture d'écran:
1:Type : Sélectionner QSL
2: Sent : Sélectionner Requested
3:Rcvd : Sélectionner Requested
4:Cliquer sur la disquette pour sauvegarder la sélection
5: Cliquer pour sauvegarder et appliquer la configuration.
Créer un QSO virtuel puis vérifier si les champs QSLreceveid et QSLsent affichent Requested.
Merci d'indiquer dans le post le contenu de "DefaultConfirmations".
73 Christian
Posted: 14 Jun 2020, 12:23
by F1TRF
bounjour Christian
j'ai réinstallé la v2.7.0.0
refait les enregistrements dans setting
et refait un contact
le probleme est toujours la
copie du dernier .json
"CT": "HAMQTH",
"S": "No",
"R": "No",
"SV": "Electronic",
"RV": "Electronic"
"CT": "CLUBLOG",
"S": "No",
"R": "No",
"SV": "Electronic",
"RV": "Electronic"
"CT": "CUSTOM",
"S": "No",
"R": "No",
"SV": "Electronic",
"RV": "Electronic"
"CT": "QSL",
"S": "No",
"R": "Requested"
"CT": "EQSL",
"S": "Requested",
"R": "Requested"
"CT": "LOTW",
"S": "Requested",
"R": "Requested"
"CT": "QRZCOM",
"S": "Requested",
"R": "Requested"
"CT": "HRDLOG",
"S": "Requested",
"R": "Requested"
Posted: 14 Jun 2020, 15:36
by F4GJC
Laurent,
J'utilise la version 2.7.0.0 et je ne rencontre pas le dysfonctionnement.
Avant d'ouvrir le fichier de configuration pour y récupérer les informations, avez-vous fermé le logiciel Log4OM ?
Dans l'affirmative, avez-vous respecté la configuration du test demandé ?
En effet, les informations présentes dans le fichier de configuration ne reflètent pas le paramétrage de la copie d'écran.
Nous aurions du avoir le résultat suivant:
"CT": "QSL",
"S": "Requested",
"R": "Requested"
et non le résultat présent dans le post
"CT": "QSL",
"S": "No",
"R": "Requested"
Pourriez-vous me confirmer que :
* vous avez effectué le test demandé ?
* le fichier de configuration utilisé se trouve dans le dossier C:\NonUtilisateurWindows\appdata\roaming\log40m2\user
Puis faire le test suivant:
Fermer log4om
modifier la section custom du fichier de configuration comme suit
"CT": "CUSTOM",
"S": "Requested",
"R": "Requested"
enregistrer le fichier puis ouvrir Log4OM et créer un QSO virtuel
73 Christian
Posted: 15 Jun 2020, 17:57
by F1TRF
bonjour Christian
après plusieurs modif et recherche, j'arrive a cette conclusion
j'ai poussé le vice jusqu’à réinstaller windows pour avoir un truc propre.
donc qso enregistré manuellement pas de probleme, tout passe en requested
qso enregistré a partir du cluster pas de probleme non plus
par contre tout ce qui arrive de wsjt-x passe en none
merci
