A local ham friend called me this afternoon and said his import of his Field Day adif file did not act as it had in the past. So, I imported my Field Day log from N1MM LOG4OM2 (Version 2.7.0.0) and noticed that the fields LOTW sent/rec, QSL sent rec, Clublog sent/rec, EQSL sent/rec were all set to No/No.
Earlier this month I had imported an ADIF file for the Kentucky QSO party and the mentioned above fields were set to requested. When I log a qso manually into the log, the fields are all set to Requested.
I was wondering what is behind the change. I resolved the issue with QSL Manager, but I have never needed to do that before.
Import of ADIF file from N1MM questions
Re: Import of ADIF file from N1MM questions
This is a known issue and is fixed in the next release, our apologies for the inconvenience.
