How many call signs have I worked?
W4EBB
Post by W4EBB »
I am on 2.8 and I am wondering how many call signs have I worked? I have over 10,000 digital QSOs but I am guessing I probably only have worked 2,500 call signs - the rest coming from duplicates on a band (I usually will re-work someone I have had a QSO with on a band if they contact me) and from working others multiple times on different bands.
I tried to figure out how it could be done in 2.8 but no joy.
Anybody know how I could do this?
Charlie
W4EBB
AE6DS
Re: How many call signs have I worked?
Post by AE6DS »
You can do that relatively quickly with PowerShell text processing.
In Log4OM:
File->Export CSV
check ONLY the call field
save to "calls.csv"
In PowerShell:
Get-Content .\calls.csv | Sort-Object -Unique | Measure-Object
You can also get a list of your 10 most frequent contacts in PowerShell:
Get-Content .\calls.csv | Group-Object -NoElement | Sort-Object -Property Count -Descending | Select-Object -First 10
Dale
W4EBB
Post by W4EBB »
Dale:
No experience with powershell.
But will try your suggestion and let you know.
Thanks,
Charlie
W4EBB
W4EBB
Post by W4EBB »
Dale:
Ran Powershell with your specs and got an unexpected answer.
Out of 10,047 contacts I estimated that probably 2,500 were unique. Mainly because it seems like most of my contacts I have worked before on other bands so I only want to count all of the multiple contacts with the same call sign as only one.
My answer was 6,644.
So I made up a test file to which I knew the answer. Ran it and the answer was correct.
So thank you on two accounts. One - I got my answer. Two you made me aware of how to use Powershell.
Thanks again and stay safe!
Charlie
W4EBB
AE6DS
Post by AE6DS »
Congrats on all the unique calls!
Glad PowerShell answered the question. I am not a PS expert (more comfortable with awk and sed) but it's useful for quickly exploring Windows text data . PS can handle multi column data reasonably well, so if there is interest in things like "how many unique Olivia contacts on 30m in 2019?" I can probably pull together some more advanced report examples.
Stay safe.
Dale
