I play Log4om, wsjt-x and jtalert, all the sw works fine.
Now I would that log4om reads band and frequency from the radio, but the cat is already used from wsjt-x.
How can I run all the sw by the CAT without any conflict?
Tnx and 73s
Inviato dal mio POCO F1 utilizzando Tapatalk
Reading Freq and band using other sw.
73s, Camillo
Re: Reading Freq and band using other sw.
Camollio,
Please check latest user manual.....?
You must use Omnirig
You must 'Run ALL programs as an administrator'
You must select OMNIRIG in WSJT NOT YOUR RADIO
It's all in the user guide, but I have to constantly repeat this because no one reads it!
Hi Terry,G4POP wrote:Camollio,
thanks for your reply, I will read with very accuracy the manual for the settings.
I hope you can play your holidays soon as possible.
73s Camillo
73s, Camillo
