Updating to the latest version
I just found the user guide on installation and upgrading. The tutorial said you must run as administrator on installation if you want to have certain settings. I don't remember doing this when I installed the software. How do I find out if I am the administrator?
Penn
G0VQY
G0VQY
Re: Updating to the latest version
Its not a case of you being an administrator that makes no difference.G0VQY wrote: 19 Aug 2020, 18:14 I just found the user guide on installation and upgrading. The tutorial said you must run as administrator on installation if you want to have certain settings. I don't remember doing this when I installed the software. How do I find out if I am the administrator?
When you install instead of double left clicking the install file right click on it and select 'Run as an administrator' from the menu. This applies to all programs to be run as such, Omnirig, WSJT, Log4om etc
I'm not sure what I'm doing wrong. I've downloaded the latest version onto my PC. If I right click I don't see anything that relates to "run as administrator", all I see is "open, cut, copy, properties & delete". There must be something I'm not doing right.
Penn
G0VQY
G0VQY
Okay, ignore my last message, I've just extracted the files again from the download and now I am seeing "run as administrator"
Penn
G0VQY
G0VQY
Well, that was pretty painless. All updated to the latest version and all my QSO's are still intact.
Penn
G0VQY
G0VQY
When I go to "QSL manager" I don't seem to be able to get the drop down to work so I can select EQSL.
Penn
G0VQY
G0VQY
I am still having problems with QSL manager this morning. Nothing on the box is clickable and I can't even close the box. Not sure what's going on.
Penn
G0VQY
G0VQY
Have you watched the YouTube tutorial 'Confirmations 3?G0VQY wrote: 21 Aug 2020, 11:45 I am still having problems with QSL manager this morning. Nothing on the box is clickable and I can't even close the box. Not sure what's going on.
https://www.youtube.com/watch?v=7cthCCVwkXg&t=12s
Hi, Terry,
Yes, watched all the videos. I've already uploaded over 1000 contacts to EQSl without any problems. However, when I went back this morning nothing works on the box. Like I have said, I can't even close the box. If I click outside the screen the box minimizes into my tray but I can only close it if I close the whole program
Penn
G0VQY
G0VQY
