Hi all,
i just moved from foundation to intermediate so now have a new callsign.
In E-Qsl it seems i now have two logs - can Log4OM pick up any QSL cards from the old log once i enter details for the new log?
Many times they arrive weeks after the actual QSO.
Multiple callsigns, e-qsl?
Re: Multiple callsigns, e-qsl?
For confirmation downloads Log4Om using only the data in the setup. Means your actual callsign and
your eQSL, LotW settings or others. What you can do is to generate a second Config for one of these
callsigns and you can use the same (complete) logbook for both. For downloading QSL´s of your old
call you have only to change the config.
Thats interesting, thanks
Had not thought a 2nd config and just popping back to it occasionally, that will work.
