Changing Column Order
First, thanks so much for adding STATE to the DX Cluster. This latest version upgrade really added many new features. Following the instructions on page 27 of the latest manual, it says to left click on the desired column and drag it to the desired position.I'm sure I'm missing something, but it wont move. I want to reposition it next to the Country.
Re: Changing Column Order
Should work, did you hold the mouse button pressed and drag horizontally?
Cancel that request. I just figured out that the cluster must be stopped before changes can be made. I did not see that mention bed in this section of the manual.
