Marconi Day 2020
Moderator: OE6CLD
OE6CLD
Marconi Day 2020
Post by OE6CLD »
I have uploaded an award definition for the Marconi Day 2020 event from the Cantabria DX Team (MD_2020). For an award you have to work special Marconi stations in Italy (all starting with IY prefix) from the 14th until the 23rd of September 2020.
Don't mix this up with the International Marconi Day IMD in April with a lot of activity from different countries.
You can find all details here: https://marconiday2020.jimdosite.com/regolamento/ (in Italian).
Valid bands: 160-80-40-30-20-17-15-12-10-6m
Modes: CW, SSB, digital modes (FT8/FT4, RTTY, PSK)
1 point: digital modes (FT8/FT4, RTTY, PSK)
2 points: SSB
3 points: CW
This means you can work any valid station 3 times on every band (CW, SSB and digital modes), valid for 3+2+1=6 points.
For an award you will need at least 30 points.
You can check the logs and download the award here: http://www.calabriadxteam.it/marconiday2020/index.htm
Please note that Log4OM only will show the worked stations and will not calculate the points for the different modes. You can check the worked modes on the "Statistics" tab.
You can see that I worked 3 CW stations (9 points), 5 stations in digital modes (3 on 40m, 2 on 30m = 5 points) and 3 in SSB (6 points). In total I have 9+5+6 = 20 points so I need 10 more points for the award.
Have fun!
Claus
Claus, OE6CLD/DJ0DX/EI7JZ
