Not able to upload to lotw
wa6gxq
Post by wa6gxq »
Greetings,
When I try to upload to lotw i get the following error:
17:46:07: INFO: ADIF File created successfully.
17:46:07: INFO: TQSL Version 2.3.1
17:46:07: ADIF file not found on path: C:\Program Files (x86)\TrustedQSL\tqsltemp\LOTW_UPLOAD_20201001174607.adi
17:46:07: LOTW END
I can export the qso's to a adif file and upload them from tqsl.
WA6GXQ
Re: Not able to upload to lotw
1. TQSL is well out of date, download the latest version
2. Change the temp path for LOTW in Log4OM Program config to something like C:\.........................appdata\roaming\Log4OM2\temp having the temp folder in the program files folder probably is not good
wa6gxq
Post by wa6gxq »
Terry,
Thank you so much for your help. that resolved the original problem. But i have another problem.. This one is i am afraid much uglier.
I tried uploading a few qsl's and i received the following error:
01:01:07: INFO: ADIF File created successfully.
01:01:07: INFO: TQSL Version 2.5.5
01:01:07: No private TQSL Password set
01:01:07: Executing TQSL with upload
01:01:07: Messages from LOTW:
01:01:07: TQSL Version 2.5.5 [v2.5.5]
01:01:07: Signing using Callsign WA6GXQ, DXCC Entity UNITED STATES OF AMERICA
01:01:07: Station Location does not match QSO details
01:01:07: The Station Location 'ITU Zone' has value '8' while QSO has '6' on line 9
01:01:07: BAND: 40m
01:01:07: CALL: VE3TGL
01:01:07: FREQ: 7.075002
01:01:07: MODE: FT8
01:01:07: MY_COUNTRY: United States
01:01:07: MY_CQ_ZONE: 5
01:01:07: MY_DXCC: 291
01:01:07: MY_GRIDSQUARE: FM06na
01:01:07: MY_ITU_ZONE: 6
01:01:07: OPERATOR: WA6GXQ
01:01:07: STATION_CALLSIGN: WA6GXQ
01:01:07: QSO_DATE: 20201001
01:01:07: TIME_ON: 231800
01:01:07: No records to upload
01:01:07: Final Status: No QSOs written(8)
01:01:07: All QSOs were duplicate or out of date range (no QSOs written)
01:01:07: LOTW END
I looked at the qso and noticed under my qth it has itu zone 6 qso zone 5 it should be itu zone 8 qso zone 5.
Your zone and station location must match that which is recorded at LOTW and in the TQSL program there is a mismatch somewhere, your issue is not a Log4OM bug its a set up problem.
Its possible the zone was set by an external program if the QSO was imported. You will also need to edit the incorrect zone in the QSO data before uploading
Check the station info tab in Log44OM config to ensure you have set the zone the same as you have recorded at LOTW and in TQSL
Also check your LOTW settings in Log4OM config to ensure the station location matches that recorded at LOTW and in TQSL
LOTW no longer just rely on your call sign and certificate matching they now also look for a location match to zones
wa6gxq
Post by wa6gxq »
Terry,
The itu was wrong. that has been corrected. The issue is qsl in my database and lotw that have the wrong itu. i have approximately 28,000 records in log4om. it seems this issue manifested in the last two years. how can i go about correcting this issue. Please don't tell me manually....
Thanks Wa6gxq
If the zone is wrong for the QSO's in Log4OM use the QSO manager to bulk edit them in one go, should take about 5 minutes
wa6gxq
Post by wa6gxq »
Terry,
Thanks for all your help. It seems i am able to up load and download now.
Once again Thank You!
