I programmed 2 receivers in Omnirig
When i active the CAT of the first receiver in log4om, all is ok
But impossible to active the CAT of the second receiver in log4om
Is it normal?
LOG4OM and OMNIRIG problem
Re: LOG4OM and OMNIRIG problem
No, i have 2 transceivers running and all is fine. Did you run Log4OM and Omnirig and/or other
related softwares as administrator as described in the user manual ? Have you different COM
ports for those 2 receivers ? If a COM is used by Omnirig1 it can´t be used for Omnirig2.
I also have 2 rigs connected to omnirig and I am using log4omv2. I can switch between rigs using Log4om. Make sure you are using 2 different com ports. I recently just upgraded to omnirig 1.19. User guide here is very helpful.ON4OM wrote: 09 Oct 2020, 07:46 I programmed 2 receivers in Omnirig
Is it normal?
Mike-W2MJP
Mike-W2MJP
I work with Omni Rig with out problem. It works fie with JTDX and both Softwares have CAT
I had version 1.19 and I move back to 1.18 with better performance... With 1.19 I had some small cuts.
73 de Jose EC6DX
73 de Jose EC6DX
EC6DX Balearic Islands
HelloEC6DX wrote: 12 Oct 2020, 15:47 Hi,
73 de Jose EC6DX
What is better about 1.18? What do you mean by cuts? I am using 1.19 and I dont see any issues
Mike-W2MJP
Mike-W2MJP
Hi...
I was using 1.19 and I changed to 1.18 because I loose conection sometimes... With V 1.18 all is better between JTDX and Log4OM
I can not explain why because I am a very poor technician... hihihi... It is my experience...
Log4OM works perfectly using Omni Rig with JTDX !!!
Jose
Jose
