LazyLog
F6EXV
LazyLog
Post by F6EXV »
Hi all
Trying to use Lazylog for the first time in real life.
I do read the info on the manual (pdf) and see all the commands.
When I type in the word s "CALL F2VX" or "CALLSIGN F2VX", it tells me {command not found}
How do I enter a callsign ?
Thanks + 73
Paul F6EXV
Thanks + 73
Paul F6EXV
Re: LazyLog
Think you have not read the user guide properly
When entering the other stations details simply type the line as follows
F6EXV sent 599 rcvd 567 #jn01pp
No need to prefix the call with anything
F6EXV
Re: LazyLog
Post by F6EXV »
I HAVE read the manual.
On the first attachment, there is no mention whatsoever on how and where to type the callsign.
On the second attachment, the explanation says the callsign is (obviously) a mandatory field, and the command is CALLSIGN.
What is obvious to you may not be obvious to others that are using some features for the first time.
I have indeed read the manual, and have even searched youtube for any tutorial on this, to no avail...
Thanks for your explanation
Paul
Thanks + 73
Paul F6EXV
Re: LazyLog
Perhaps the columns were confusing here is an explanation of what each area is explaining (Apologies for the typo)
