Hi all
I have set the LoTW QSL configuration to show "NO" as the sent default. It works fine if I enter a QSO manually, or if I import a log contest (as I did yesterday).
But I notice when the QSOs come from JTDX, the LoTW received shows "requested".
How can I change that ? I would like it to show "No"
Thanks + 73
Paul F6EXV
Import and LoTW
Re: Import and LoTW
Paul,F6EXV wrote: 27 Oct 2020, 14:56 Hi all
Thanks + 73
Paul F6EXV
There are settings in JTAlert that trigger the requested label. You can "un-tic" that selection in JTAlert settings.
Re: Import and LoTW
Nolan
I have gone though all the options in the JTAlert settings, have not found the culprit.
Can you tell me more ?
Thanks + 73
Paul F6EXV
Thanks + 73
Paul F6EXV
Thanks + 73
Paul F6EXV
Paul F6EXV
Re: Import and LoTW
Paul,F6EXV wrote: 27 Oct 2020, 19:04 Nolan
Thanks + 73
Paul F6EXV
JTAlert has a page with a bunch of items that I don't use and one is about having JTAlert send the QSO to Log4OM V2 with a "requested" label.
Image below ...
- 5_JTA-Logging.JPG (143.12 KiB) Viewed 1386 times
Re: Import and LoTW
Nolan
That is where I had to look !
Problem solved, thanks a lot
Paul F6EXV
Paul F6EXV
Thanks + 73
Paul F6EXV
Paul F6EXV
