How do I keep Omnirig from turning Ci-V transceive off.
w7rms
Post by w7rms »
My Acom 700S amp needs Ci-V transceive on to get band data from my Icom 7300 but it is turned off every time I start log4om. Is there a way to prevent this?
Re: How do I keep Omnirig from turning Ci-V transceive off.
w7rms wrote: 27 Oct 2020, 22:12 My Acom 700S amp needs Ci-V transceive on to get band data from my Icom 7300 but it is turned off every time I start log4om. Is there a way to prevent this?
I think if you look at the 7300 omnirig ini file you will see the command turning it off is in there and you can edit the commands yourself.
However I beleive that it is necessary for it to be off for CAT control?
Cant you use the ATU or ACC sockets to connect to your amp?
w7rms
Post by w7rms »
Commenting out that setting in the .rig file fixed the problem. The REMOTE port is used to talk to the amp. You have to set CI-V USB Port > Unlink from [Remote] so that both the remote port and the USB port can be used independently and CI-V Transceive needs to be on.
All is good now. Thanks.
LZ2FP
Post by LZ2FP »
Hi!
The same was situation for me. On ICOM 7300 default settings for CI-V Transceive is ON. It is nesessary for working communication via remote port. In my situation EVERY software, using Omni Rig stops my amplifier to communicate with the radio. I think, this has to be corrected by Omni rig autor. Now my Omni turns CI-V Transceive in On by this changes in IC 7300 ini file in C\Program files (x86)\Afreet\OmniRig\Rigs
[INIT2]
;Turn CI-V transceive ON
Command=FEFE94E0.1A050071.01.FD
ReplyLength=16
Validate=FEFE94E01A05007101FD.FEFEE094FBFD
PY5CV
Post by PY5CV »
GREAT !!!
Thank you LZ2FP for the solution that bothered me. I use the CI-V ON (IC-7300) to automate my Antennas by Frequency and it was constantly OFF and I didn't know what it was.
Thank you very much
73´s PY5CV Brazil
