No QSO's on LOG4OM
zl1mto
No QSO's on LOG4OM
Post by zl1mto »
After quite a long research on the pros and cons for logging software I finally found something that seems to do what I am after. I recently installed the Log4OM 2 version 2.9.0.0 and am working together with the WSJT-X 2.2.2 application for FT8.
Anyway, so far I have been very happy with the features of Log4OM application, it is easy to use, the cluster feature is great, the communication between WSJT-X and Log4OM is happening (when I click on a station o WSJT-X the data of the station is shown on LOG4OM), etc...
Except that the MOST IMPORTANT thing I am after is not working.
I have spent many hours playing with all settings, databases, etc...but nothing worked. I just want to have a QSO logged in WSJT-X automatically logged into LOg4OM. However, as you can see on the picture attached the screen is always blank.
I have also created a log directly into Log4OM and saved it just to see if the issue is with the integration but no....it will not display the log that I saved.
Does anyone have any idea on how to fix this ?
Marcelo
ZL1MTO
Re: No QSO's on LOG4OM
I cant see from your image if a database is connected, see image below it should show path and database name
If there is a path shown please inform us what it is
zl1mto
Post by zl1mto »
Thanks for your message.
Yes, the database is connected. Please see a screenshot attached.
Move the database to your documents folder or to a cloud storage like Dropbox, you created it in the wrong place
zl1mto
Post by zl1mto »
OK thanks.
I have already moved it and will give it a try.
Marcelo
zl1mto
Post by zl1mto »
Thanks Terry.....that was the issue.
Probably the application could not access the file since it didn't have permissions in that folder. It is working as it should.
Thanks again
Marcelo
ZL1MTO
