Page 1 of 2
LoTW
Posted: 08 Nov 2020, 12:51
by F6EXV
Hi
Following previous message which remained unanswered, here is the situation.
On both the confirmation configuration, and the external services, I have configured the LoTW sent field to NO.
See the 2 pictures attached.
The upload upon exit is not done, despite the little message saying it is.
When I changed both to "Requested", it seams to work.
Is it normal that it does not work when both are set to "NO" ?
Thanks + 73
Re: LoTW
Posted: 08 Nov 2020, 13:23
With NO settings does a manual upload from the QSL Manager work?
Re: LoTW
Posted: 08 Nov 2020, 13:37
by F6EXV
Yes
Re: LoTW
Posted: 08 Nov 2020, 13:47
What version of Trusted QSL and Log4om are you using
Re: LoTW
Posted: 08 Nov 2020, 14:29
by F6EXV
Log4OM version 2.9.0.0 and TQSL version 2.5.5, latest ones for both I think
Paul
Re: LoTW
Posted: 08 Nov 2020, 14:34
Have you tried turning on trace mode in the help menu and then closing log4om doing an auto upload to LOTW
Then reopen log4om and inspect the log file to see what happened last time you closed log4om?
Re: LoTW
Posted: 08 Nov 2020, 14:53
by F6EXV
The "last exception) box in the diagnostic form is empty after doing what you requested me to.
Re: LoTW
Posted: 08 Nov 2020, 14:57
Are you able to copy and paste the all of the lines from the log file that show records from the time you start to close log4om until it is completely closed on this forum?
Re: LoTW
Posted: 08 Nov 2020, 15:01
by F6EXV
No, they disappear too fast, I cannot make that little screen bigger, and I cannot stop the lines from moving up.
If there is a way to do both, I don't know how to.
Re: LoTW
Posted: 08 Nov 2020, 15:04
F6EXV wrote: 08 Nov 2020, 15:01 No, they disappear too fast, I cannot make that little screen bigger, and I cannot stop the lines from moving up.
Did you try saving the log file and then opening it in notepad?
You can make the window full screen as with all Win 10 windows
