User Awards Lost in Update
sp7dod
Post by sp7dod »
Error Report:
I lost all user-defined awards after last upgrade.
Re: User Awards Lost in Update
Did you try updating the awards?
vk1di
Post by vk1di »
Like previous updates, lost all my Custom Awards.
Update Resources, Log4OM Awards does not work. Ended up importing them in one at a time from exports.
Ian VK1DI
on6at
Post by on6at »
The same happened here.
Have to set everything manually again. Still a lot of work!
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
f4bkt
Post by f4bkt »
If you write your own awards, you must make a backup before updating the list or upgrading to a new version.
Otherwise, your awards are lost.
Before making any changes, you must make a backup of the awards.
ScreenHunter_210 Nov. 30 08.18.jpg (12.07 KiB) Viewed 2812 times
Then you will be able to import your own awards into the new list and everything will go back to normal.
73 Phil
