MFSK as mode
G4DWV
MFSK as mode
Post by G4DWV »
I have no idea what MFSK is, but I am certain that I have never used it.
Searching in Log4OM (2.10.0.0) does not reveal any MFSK in the mode field. However, there are 420 in the exported ADIF file.
Any idea what is going on and how can this be fixed?
Mni tnx.
F6FLU
Re: MFSK as mode
Post by F6FLU »
Hi
MFSK is the mode for FT4
FT8 is one mode but FT4 is a submode from MFSK
Normaly if you have MODE=MFSK then you have to SUBMODE=FT4
Dan - F6FLU
https://F6FLU.org
ve3wej
Re: MFSK as mode
Post by ve3wej »
the problem is qso partner are qsling on eqsl as mfsk, not ft4 and my log will not match it..
the logging programs need to get on the same way of handling ft4....
Dave ve3wej / ve3ie
Re: MFSK as mode
That´s a problem with the log of your QSO partner. Log4OM handles this correct. If you have correct
FT4 contacts at eQSL it show´s MFSK (FT4) at the eQSL page. All this contacts are matching. These
which are uploaded as MFSK only (from your qso partners) did not match but we can´t do anything
about this problem.
