Page 1 of 2
Error uploading LOTW
Posted: 26 Nov 2020, 03:38
by ZP5RPO
Hi, I have received this error when trying to upload to LOTW:
INFO: ADIF File created successfully.
INFO: TQSL Version 2.5.7
No private TQSL Password set
Executing TQSL with upload
Messages from LOTW:
TQSL Version 2.5.7 [v2.5.7]
No se pudo encontrar la ubicación de estación seleccionada
Final Status: Command Syntax Error(10)
Command syntax error
LOTW END
Re: Error uploading LOTW
Posted: 26 Nov 2020, 04:58
by DF5WW
Wrong TQSL setup. You have no Station Location defined or the used Station Location
was not found (maybe a type error in your settings). Check in TQSL what you have
setted up there. Check that upper and lowercase letters are correct.
- 1.png (22.77 KiB) Viewed 4558 times
Posted: 26 Nov 2020, 18:52
by ZP5RPO
Hi Juergen.
Thanks for answer, I think is OK my location:
- TQSL.jpg (74.06 KiB) Viewed 4541 times
- TQSL1.jpg (49.39 KiB) Viewed 4541 times
Posted: 26 Nov 2020, 19:41
by DF5WW
Think the problem isn´t a Log4OM related problem. Your station location has 2 empty spaces and
a "-" inbetween. Try to change your station location in TQSL to maybe "Asencion" and if this one
is setted up use the same in Log4OM settings for the LotW upload. Don´t use special characters
but upper case and lower case must be identical that TQSL working correctly.
Posted: 26 Nov 2020, 21:46
by ZP5RPO
Juergen.
I have changed the location to "Asunción" and the same error apears, in the version 2.9.0.0 the location "ZP5RPO - Asunción" worked fine.
Posted: 26 Nov 2020, 23:22
Do your zones in TQSL match the zones on your LOTW profile on the LOTW website?
Posted: 27 Nov 2020, 02:36
by ZP5RPO
Hi Terry.
THis is the info I have found in the website of LOTW
- LOTW cert.jpg (36.18 KiB) Viewed 4516 times
I can upload manually the adif of my new QSO's.
Posted: 27 Nov 2020, 07:31
ZP5RPO wrote: 27 Nov 2020, 02:36
By using TQSL?
Posted: 27 Nov 2020, 14:15
by ZP5RPO
Yes by using TQSL
- LOTW upload.jpg (83.61 KiB) Viewed 4499 times
Posted: 27 Nov 2020, 16:07
OK What you need to do is this
1. Set Log4OM to TRACE MODE in the help menu
2. Attempt a Manual LOTW upload from Log4om using the QSL manager
3. Complete a support request from the help menu, please check the box include ADIF
4. Email the support request zip file to me at g4pop (at) arrl.net with a reference to this forum thread
Note:
Do not restart Log4OM after you set trace mode or the program will default back to info mode
