DXcluster Window
ON7CL
DXcluster Window
Post by ON7CL »
All,
When I see my DXcluster window, all is green, like you see.
In the statistic window above you see that I didn't have T6 confirmed on 15m, but the cluster leaves it green, I have to click on the spot to see if I did work or have confirmed that country.
Is there something wrong with my settings in the cluster ?
My setting:
New countries are red.
Not worked or confirmed countries are blue.
Confirmed countries are green.
Info welcome.
73 - Rudi - ON7CL
CT1BXX
Re: DXcluster Window
Post by CT1BXX »
Hello Rudi,
From what you say, you have no color in the option: "Band / Mode not wrkd/conf" the second option.
Please change the color and certainly everything will be as it should, here it works perfectly.
Have a nice weekend
73 Manuel Fernando CT1BXX
Rudi,
The display you have selected for the cluster is confirming that you have worked the COUNTRY on those bands and modes
Select the VIEW button to the right of the cluster and change the view to the confirmation type that you prefer e.g. QSL and LOTW
Nothing to do with the colours that you selected in the config
ON7CL
Post by ON7CL »
Ok working now.
