Setup IC7610 with Fldigi
pc9t
Post by pc9t »
I am new to Log4omNG but struggling to set it up.
I have a Icom IC7610 and can connect it to my Ic7610 , but then I'am struggling to connect to Fldigi and also to Pst rotator and WSJT X
I have several things tried but with no good luck.
Have Win4icomsuite installed and com0com but with following the manual I can't setup I correct to work it all.
the only thing I got working is that de log from Fldigi log to log4omNG.
Hope someone can help me set it up correctly, otherwise I have to go back to MacOS.
But I hope to can use it because the opportunity to use it remotely when in the summer we are on the boat her in holland somewhere.
TX: Flexradio 6400 / Flex Tuner Genius XL / Icom IC9700 / Mic. Heil PR781 / Antenne Hexbeam by SP6CYN / Homemade G5RV / Kelemen 40 Meter Dipole
Re: Setup IC7610 with Fldigi
Follow our user guide for the Fldigi with IC7300 it's virtually the same
I also use Win4icom with log4om and Omnirig and wsjt using Icom USB with Fldigi logging via UDP and rig control with Hamlib to rear acc socket - make sure you unlink the connections in the Icom menu
