Propagation view band selection
K0HB
Post by K0HB »
The propagation view in the main UI (F9) automatically follows the current operating band selection.
The same(?) window in the detached view ( View > Propagation ) requires manual band selection.
DE Hans, KØHB
"Just a boy and his radio"
Superstition Trails ----> http://OldSlowHans.com
Re: Propagation view band selection
K0HB wrote: 26 Dec 2020, 03:31 The propagation view in the main UI (F9) automatically follows the current operating band selection.
Only if you open the window AFTER the call/band/mode lookup calculation has been done! Its already happened when you open the window!
Once the window is open ant further entries are automatically calculated
K0HB
Post by K0HB »
There seems to be an issue with that. See below.
I set myself up on 80 meters with both versions open, with WSJT-X feeding Log4OM. ("F9" on top, "View > Propagation below.)
As I worked different stations on 80m, both windows reflected the same information as expected..
Then I QSY'd from 80 to 40m.
The lower window ( "View > Propagation" ) did not follow, but stayed on 80m. Now when I work a new station, it does, in fact, recalculate. But provides 80m (not 40m) results.
Running v2.11.0.0 and Win10 PRO.
DE Hans, KØHB
