Rebuild Statistics
F6FLU
Rebuild Statistics
Post by F6FLU »
I send the command
Settings / Maintenance / Rebuild statistics
but it seems to do nothing, Log4OM gives me back control immediately and visually I do not see anything being executed ...
Is this function operational and if so how do you see it
Dan - F6FLU
https://F6FLU.org
Re: Rebuild Statistics
Help/Realtime log
F6FLU
Post by F6FLU »
OK Terry
another function that I had not seen ...:-)
would it not be wise if we run this command to automatically open this window (Realtime Log) ?
Dan - F6FLU
https://F6FLU.org
F6FLU wrote: 27 Dec 2020, 08:35 OK Terry
What is the point? you also have a indicator in the main QSO entry area which indicates activity and when clicked on shows what the activity was and the command is intended to run in the background anyway!
F6FLU
Post by F6FLU »
well in principle when we launch an order we expect to have a window that opens indicating the progress of the order
maybe the icon is enough but I hadn't even noticed ..
launching a command without seeing anything suggests that nothing is happening
well it's just my opinion if you like it like that...
Dan - F6FLU
https://F6FLU.org
