Setting filters via CIV commands
Posted: 29 Dec 2020, 20:02
by Wo2t
I'm trying to figure out how to use the Omni Rig CIV address to set radio digital modes and filters during band changes. I'm running an Icom 7600.
Re: Setting filters via CIV commands
Posted: 29 Dec 2020, 20:38
As in using WSJT?
Posted: 30 Dec 2020, 00:32
by Wo2t
WSJT and MixW at times. I think that I can modify the .ini in Omni Rig. I think I just need to find the numerical for filter 1, filter 2, USB-D, ECT. I'm running Omni Rig 1.9.
Posted: 30 Dec 2020, 08:34
No need to modify
Make sure that you use the Omnirig IC7600v2 Data ini file
Follow the set up instructions in our user guide for WSJT
Now when you change bands in WSJT it will auto select USB-D
Works fine for me on 7600 and 7300
Posted: 30 Dec 2020, 15:35
by Wo2t
I fooled around with OmniRig 7600v.2. What I find is that If a select a FT8 freq. the 7600 goes to CW-R.
Could someone send me clean Rig file for the 7600 for comparison.
[email protected]
Thanks!
Posted: 30 Dec 2020, 15:52
by KI5IO
Wo2t wrote: 30 Dec 2020, 15:35 I fooled around with OmniRig 7600v.2. What I find is that If a select a FT8 freq. the 7600 goes to CW-R.
[email protected]
Thanks!
OM,
You can get the ini files directly from DXAtlas at this URL: http://www.dxatlas.com/Download.asp
Go to that link and scroll down to the section labeled OmniRig. The current INI zip was updated on 11/02/2020.
Posted: 30 Dec 2020, 16:05
by Wo2t
Thank you Sir! HNY
