Log file not uploaded to LOTW
n4hcr
Post by n4hcr »
Log4OM doesn't seem to be uploading to LOTW. It used to work fine, but then a few weeks ago, it apparently stopped. I'm at a loss as to why this might be. I haven't made any changes to the software.
Wayne, N4HCR
Re: Log file not uploaded to LOTW
LOG4OM VERSION NUMBER?
TQSL VERSION NUMBER?
n4hcr
Post by n4hcr »
I see that I need to update both TSQL and Log4OM, so I'll do that and see if there's still a problem.
n4hcr
Post by n4hcr »
I've updated TSQL and Log4OM. Current versions are 2.57 and 2.11.0.0.
I've checked the log file and my contacts are there. However they're not being uploaded. I went into settings and checked to confirm that automatic upload to LOTW is selected, and it is. I'm not sure what else to check. Suggestions appreciated.
Wayne N4HCR
n4hcr wrote: 31 Dec 2020, 04:12 I've updated TSQL and Log4OM. Current versions are 2.57 and 2.11.0.0.
Wayne N4HCR
Wayne,
Go to QSL Manager and select one or two of your Q's and try a "manual" upload to LOTW. Check to make sure that works.
Probably the usual issue of either incorrect password or station location or state
