Documentation
F6FLU
Documentation
Post by F6FLU »
On the last manual (Updated: 29/12/2020 11:10 AM)
Page #56 : QSO ExportBulk exporting
•Add a name and location by clicking the 'Export' button
CE_ 2020-12-31 à 14.55.32.jpg (79.02 KiB) Viewed 1697 times
I have not this "export button" but only "ADIF" button
Export ADIF 2020-12-31 144117.jpg (25.29 KiB) Viewed 1697 times
I suppose it lacks a manipulation to do before to get this button ?
But hey, it doesn't matter, just to know because by clicking on this "ADIF" button everything is fine; it's just to correctly translate the methodology ...
Thanks and HNY
Dan - F6FLU
https://F6FLU.org
Re: Documentation
You have to use export adif in the file menu. If the window pops up use the ADIF button.
If you have done you have to set an output filename and then you will get this. It´s a simple
Windows function.
F6FLU
Re: Documentation
Post by F6FLU »
DF5WW wrote: 31 Dec 2020, 14:18 You have to use export adif in the file menu. If the window pops up use the ADIF button.
Windows function.
yes I understood that well but it is not described like that...
that's why I'm asking the question...
Dan - F6FLU
https://F6FLU.org
Re: Documentation
I have simplified the user guide re the ADIF export process, added extra images, reformatted the text and included expanded explanations to make it easily understandable by everyone.
The revised user guide is available now for download.
F6FLU
Re: Documentation
Post by F6FLU »
G4POP wrote: 31 Dec 2020, 14:45 I have simplified the user guide re the ADIF export process, added extra images, reformatted the text and included expanded explanations to make it easily understandable by everyone.
OK Terry many thanks...
Can you tell me if you take into account my question about the export in CSV format that I posted in the error reports section ?
Thank you and HNY
Dan - F6FLU
https://F6FLU.org
Re: Documentation
Answered on the other thread
