Entry field wipe
m0eas
Entry field wipe
Post by m0eas »
Is there any feature / parameter which activates clearing/ wiping the callsign entry field if the frequency is changed?
I am aware pressing ESC works but not always if I happen to have clicked into a different application such as HDSDR.
N1MM has this. Very useful as often I just enter a callsign in the box to view information whilst scanning through the band.
Re: Entry field wipe
m0eas wrote: 05 Jan 2021, 11:49 Is there any feature / parameter which activates clearing/ wiping the callsign entry field if the frequency is changed?
OM,
Tapping the red X at upper right corner of Main UI will wipe all information present for that entered callsign.
That is how I check stations while scanning bands.
m0eas
Post by m0eas »
Is it possible to request this as a new feature?
Moved thread to Feature suggestions
Not a thing I would want personally, sounds like a PITA unless it could be disabled! especially as there are other safer ways to clear the field like esc, backspace or the cancel X
m0eas
Post by m0eas »
Thanks, yes certainly would need to be a parameterised feature and maybe operate when frequency changed by a reasonable margin.
