Propagation Prediction Question
WA2SQQ
Post by WA2SQQ »
I've been using he Propagation Prediction feature quite a bit and I find it to be fairly accurate. I see that the predictions are using 100W as one of the variables. If I'm using higher power, is there a way to change this? I'm assuming that higher power can make marginal propagation possible.
Re: Propagation Prediction Question
No there is no way to change the aerial used in the calculation, these are formats set by Voacap
WA2SQQ
Post by WA2SQQ »
Thanks very much!
m5aec
Post by m5aec »
It would seem that under F9 you select Propagation from Graph/Raw data/Propagation, to show shaded map the power used is that set in F4 may station.
