Db error
Ab6kx
Db error
Post by Ab6kx »
Hi all. New user of log4om.
Everything is fine until I shut down the program. When I launch it the db is corrupt and I have to create new db and import back up. The log references db being read only. I have run the program as administrator but not change. Eberything is fine until I close and re open. While open all functions work.
Thanks in advance
Re: Db error
Where have you stored the sqlite database, what foldér?
Ab6kx
Re: Db error
Post by Ab6kx »
In my documents folder. And this is windows 10
Re: Db error
Have you checked that the folder of the file are not write protected like read only?
Clearly this is an authority issue so try running Log4OM as an administrator
Ab6kx
Re: Db error
Post by Ab6kx »
Hi there. I seem to have found the solution. Run as admin wasnt needed but rather AVG antivirus needed to have the program added as an exception in order to allot it to write a db file to my documents. I have added exception and it seems to work at this time. Thanks for the assistance.
Re: Db error
:D :D :D :D
Re: Db error
By the way, if you use Log4OM togehter with Omnirig and different Softwares like WSJT-X/JTDX
it´s absloutely needed to run all of this softwares with administrator rights. Only this makes it
possible that the multithreading in Omnirig can work.
Only as a remeinder ...
F4WBL
Re: Db error
Post by F4WBL »
A comment if you have de database error = Stop your antivirus
A friend of mine had the following error
[EXCEPTION] attempt to write a readonly database
After investigation
It was AVAST antivirus that was creating the trouble
Regards
F4WBL
