Hi, when i start the pc and open log4om v2 the frequency says off line. If i then click to power and restart and open log4om again it all works.
any ideas. using omni rig and auto start is on.
cat not starting
Re: cat not starting
Sounds like the usb port is not available when the pc is first started
Did you wait for a couple of minutes then in log4om go to connect and CAT control and click start CAT?
