County modified by LoTW after confirmations
EA7KJE
Post by EA7KJE »
Hi all,
Me and other friends has observed that after downloaded confirmations by LoTW, this changes the data written on the County.
Her I left you some images to see what I say...
Thank you all!!
Fernando EA7KJE
Re: County modified by LoTW after confirmations
But it has not changed the county it is only the format/syntax that altered, this is just due to the way it is stored and resolved for ADIF dont worry about it
Time to worry is when a county gets changed from Maddison to Orange or similar
EA7KJE
Post by EA7KJE »
So there is not a problem, only a text change without no more importance, just a minor text change ...
Even if only for the aesthetic aspect of said column, could something be done to avoid these changes and not have to correct one by one?
It is something that other users ask me ...
Thank you Terry!!
EA7KJE wrote: 23 Feb 2021, 09:10
Yes you could request that LOTW stick to the ADIF format
EA7KJE
Post by EA7KJE »
Ohh, I was unaware that LoTW was not using to the ADIF standard ...
Thanks for the info!!
EA7KJE wrote: 26 Feb 2021, 07:17 Ohh, I was unaware that LoTW was not using to the ADIF standard ...
They use the parts they want to and then also use some syntax of their own which is not ADIF
