When I try to send a spot from log4om-2 It doesn't work.
When I try through Clusters it says that I must be registered to send spots. No spot sent.
I then go to the website GB7BAA which accepts me and presumably knows about me from the past.
When I send a spot from the website all works as it should.
log4om knows about me as does the cluster.
Could you please advise me what I must do (in half Syllables please) to get them to work together.
Many thanks Bob
Sending Spots
Re: Sending Spots
Use whatever call sign and password you use to login to the cluster elsewhere in the cluster setup in Log4OM
Re: Sending Spots
Bob,g4whx wrote: 25 Feb 2021, 17:13 When I try to send a spot from log4om-2 It doesn't work.
Many thanks Bob
You must be logged into the cluster you are trying to send the spots to. Page 66 of the current User Guide ( 08/02/2021 - 12:49 PM ) is attached below.
- SendSpottoCluster.JPG (19.76 KiB) Viewed 1710 times
