Hi All, Have been succesfully using Log40M for over a year on a Windows 7 Pro computer with 8gb Ram. Recently updaed Log40M to versions 2.11.0.0 and all is working OK with the exception of the Import ADIF button. When clicked on there is no reaction or function. All export facilities work as does everything else with in the program. I have exported my files and then deleted the program and carried out registry and other cleaning taks before reinstalling the program with out success. The Import ADIF button is still not functioning. Any ideas please?
Many thanks
Ken G0EKH
Import ADIF stopped working
Re: Import ADIF stopped working
Hi Ken,
which "Import ADIF Button" do you mean ? The entry in the File menu or the import Button in the
import window that pops up if you hit "Import Adif" in the File menu ?
If it´s in the Import window you have first to navigate with "Load" to an ADIF and double klick it
before the Import button is visible. On my end all is working fine.
Hi Juergen, Many thanks for your reply.
The button which is not responding is the first one, MAIN SCREEN .> FILE > IMPORT ADIF.
However I have now solved the problem... I reloaded the program and created a new SQLITE database and found that all is working ok.
I have therefore examined the original database and found that it was corrupted.
The Import facility now works properly with a new database.
Again, many thanks for you quick reply and also for being a member of a great team.
I will look up on how to make a donation for the program.
Best 73
Ken G0EKH
Best 73
Ken G0EKH
