FL digi
KB1FGC
FL digi
Post by KB1FGC »
I have FL digi installed and followed all the directions.I lsetup the COM splitter Eterlogic.When I tried connecting my rig control to my radio on LOG4OM it wouldn't work,So I disabled the splitter and it works.In Eterlogic I have Com 4 as my port to the radio.And virtual port for Com 5.FLdigi is on com5 and I put LOG4OM on com 5 but then the radio doesn't work with that setting.Can you tell me what I may have wrong.Log 4om only worked when Eterlogic was disabled and on Com4.The setting I use in Windows.
Thanks Rich
73 KB1FGC
Re: FL digi
KB1FGC wrote: 24 Mar 2021, 03:46 I have FL digi installed and followed all the directions. I setup the COM splitter Eterlogic. When I tried connecting my rig control to my radio on LOG4OM it wouldn't work, So I disabled the splitter and it works In Eterlogic I have Com 4 as my port to the radio. And virtual port for Com 5.FLdigi is on com5 and I put LOG4OM on com 5 but then the radio doesn't work with that setting. Can you tell me what I may have wrong. Log4OM only worked when Eterlogic was disabled and on Com4.The setting I use in Windows.
What radio are you using?
Sounds like you have the VSP set up incorrectly
KB1FGC
Re: FL digi
Post by KB1FGC »
Hello Terry.I'm using a Kenwood TS2000.I figured out how to get the rig control,I think I never put the port number in on Fldigi.The odd thing is,It seems to work without the Virtual port.I'm confused as I have Fl Digi set to Com 5 but I erased the port settings.So not sure how it works.I was confused on the Virtual port setting.I assume to use Split mode and set log4om and FLdigi on same Com port.?Right now Fl digi is set to com 5 and Log4om to Com4.Maybe that's why the radio can control FLdigi but I can't control the radio with FLdigi.So still not out of the dark.
Thanks Rich
73 KB1FGC
