Contest setup for CQ WW WPX
ve2wnf
Post by ve2wnf »
Hello, I want to know what should I set under contest setting ? either fixed string or auto generated ?
it's my first time trying this contest and would like to set it up properly. If it's fixed string, what should I put in there ? same thing for auto generate ?
Thanks very much, if you can reply soon, contest is this weekend
73 André
Re: Contest setup for CQ WW WPX
Auto generate will generate consecutive serial exchange numbers like 001, 002, 003 etc
As for the fixed string it depends what the contest requires, check the contest site for info
