AutoStart rigctld does not work
w9mdb
Post by w9mdb »
Added rigctld to autostart with Log4OMV2 but Log4OMV2 tries and fails to connect to rigctld before rigctld actually starts.
Maybe we need another profile under the AutoStart for an earlier startup to rigctld for example?
2021-04-03 14:51:01.9199 INFO: [DatabaseManagement] : *** Connected to database C:\Users\cfogr\AppData\ADIFMaster\WA1SXK.SQLite ***
2021-04-03 14:51:01.9239 INFO: [ProgramScheduler] : Loading user scheduler configuration from file C:\Users\cfogr\AppData\Roaming\Log4OM2\user\scheduler_7d1571ca264543fe83b1657775894cc1_user.xml
2021-04-03 14:51:01.9259 INFO: [ProgramScheduler] : Executing scheduler for OnProfileOpen
2021-04-03 14:51:02.0386 INFO: [#=zII2Ry9hDtKOV4AVh1w==] : [HAMLIB] Starting Hamlib service
2021-04-03 14:51:02.0386 INFO: [#=zII2Ry9hDtKOV4AVh1w==] : [HAMLIB] Using existing connection: True
2021-04-03 14:51:03.0145 INFO: [#=zUNn6qXDi2m_YM9xJx63lR2g=] : Starting UDP listener on port 2236 for service JTALERT/ADIF_MESSAGE
2021-04-03 14:51:03.0145 INFO: [#=zvUHQiFq7qAqevRQy1KZQqxs=] : Starting remote control on port 2241
2021-04-03 14:51:03.0205 INFO: [FLDigiManagement] : Initializing FLDigi connection
2021-04-03 14:51:03.0355 INFO: * [Initialization][1142 ms] : User profile opened
2021-04-03 14:51:03.0445 INFO: [#=zgx$UsMc=] : Starting TALK client
2021-04-03 14:51:03.0794 INFO: [ucSmallCAT] : Rig changed. Updating maximum number of rigs to 1
2021-04-03 14:51:03.0853 INFO: [ProgramScheduler] : Executing scheduler for AfterStart
2021-04-03 14:51:03.5720 WARN: [FwFile][ComposeFilename] : ComposeUserFilename [load]: Base File not found file C:\Users\cfogr\AppData\Roaming\Log4OM2\user\readmessages.txt
2021-04-03 14:51:03.5731 WARN: [FwFile][LoadFileAsList] : LoadFileAsList: No text file found
2021-04-03 14:51:04.0577 INFO: [#=zDTJJAI9PPw4givWEa6$kq8c=] : Updating worked before list...
2021-04-03 14:51:04.4686 INFO: * [#=zQARorvpKnAQh6OqmNTPSczw=][2556 ms] : Recalculating statistics asynchronous process completed
2021-04-03 14:51:06.0494 ERROR: [HamlibEngine][#=z4rHSZTfxUtTYt4fo8rX8OZQ=] : [EXCEPTION] No connection could be made because the target machine actively refused it 127.0.0.1:4532 System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 127.0.0.1:4532
at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port)
at L4ONG.BL.CAT.HamlibEngine.#=z4rHSZTfxUtTYt4fo8rX8OZQ=()
2021-04-03 14:51:06.0544 INFO: [HamlibEngine] : [HAMLIB] Stop polling. Timeout True
2021-04-03 14:51:06.0554 INFO: [ProgramStorage] : [CAT STATUS CHANGED] Running: False
2021-04-03 14:51:06.3970 INFO: [#=z6l6DNsicx8eAhWK0sVDMAkj4UL3f] : Loading Geomagnetic data series
2021-04-03 14:51:06.3980 INFO: [#=z6l6DNsicx8eAhWK0sVDMAkj4UL3f] : GEOMAGNETIC DATA (DGD) downloading from ftp://ftp.swpc.noaa.gov/pub/latest/DGD.txt
2021-04-03 14:51:08.0607 INFO: [#=z6l6DNsicx8eAhWK0sVDMAkj4UL3f] : GEOMAGNETIC DATA (DGD) load from file completed
2021-04-03 14:51:08.0607 INFO: [#=zv0RMRbrOrMUfL3E4poy0jlmSkvbH] : Loading Solar data series
2021-04-03 14:51:08.0617 INFO: [#=zv0RMRbrOrMUfL3E4poy0jlmSkvbH] : GEOMAGNETIC DATA (DSD) downloading from ftp://ftp.swpc.noaa.gov/pub/latest/DSD.txt
2021-04-03 14:51:08.3100 INFO: [#=zv0RMRbrOrMUfL3E4poy0jlmSkvbH] : GEOMAGNETIC DATA (DSD) load from file completed
2021-04-03 14:51:08.3110 INFO: [#=zrDE9PuYUH2f8kwpD11IO6p7zjn0blQNll8gZT2I=] : Loading Predicted Solar data
2021-04-03 14:51:08.3110 INFO: [#=zrDE9PuYUH2f8kwpD11IO6p7zjn0blQNll8gZT2I=] : GEOMAGNETIC DATA (Predicted) downloading from https://services.swpc.noaa.gov/json/sol ... cycle.json
2021-04-03 14:51:08.7116 INFO: [#=zrDE9PuYUH2f8kwpD11IO6p7zjn0blQNll8gZT2I=] : GEOMAGNETIC DATA (Predicted) load from file completed
2021-04-03 14:51:08.7275 INFO: [#=zQDvSFS1_LxgQrFlKnGAoP76ZPn4_yfuvwQ==] : Calculating HOURLY VOACAP data: EM95lf with 100.0 watts and 0 sun spots on hour: 14
2021-04-03 14:51:09.1175 INFO: [#=zQDvSFS1_LxgQrFlKnGAoP76ZPn4_yfuvwQ==] : Hourly VOACAP calculation completed
2021-04-03 14:51:09.1514 INFO: [#=zfo_zECi5y_tjQeDk2w==] : Executing C:\Users\cfogr\AppData\Roaming\Log4OM2\hamlib\rigctld.exe -m 4 -vvv -Z
