Propagation - 10W used in calculation
VK4FDB
Post by VK4FDB »
Really sorry if this is me just being idiotic and not RTFM correctly.
I've set my radio power output to 100W in the General Settings - Station Configuration.
However, in the propagation tab - propagation button, it still calculates propagation based on TX POWER of 10.0
Any ideas how to fix this?
Re: Propagation - 10W used in calculation
Well it worked for me, did you click on generate after changing the power?
BTW YOU DONT STATE WHICH LOG$OM VERSION YOUR USING
25watt (FILEminimizer).jpg (115.32 KiB) Viewed 2167 times
100watt (FILEminimizer).jpg (115.43 KiB) Viewed 2167 times
VK4FDB
Post by VK4FDB »
So sorry for the delay Terry.
I've attached a screenshot. Yes, pressed generate after adjusting the power.
Did you try with a call sign entered?
The change of power field relates to a current ask being entered its not a dynamic link to the propo screen without that.
So with a call sign entered, change your power and click generate
VK4FDB
Post by VK4FDB »
I did try it with a callsign entered, then pressed generate. Same issue.
Well I cannot understand why this does not work for you and my only thought is that there is a corrupted file somewhere so perhaps an uninstall before reinstall might fix it.
If you do that dont forget to make a backup
