Refresh connection
Refresh connection
Occasionally, log4om will display offline, usually after I make a manual change with my radio. When this happens I close log4om and restart it, and all is well. Is there a menu function to "reset" my radio connection rather than doing the open/close dance?
Re: Refresh connection
Again Hamlib or Omnirig?
Log4om release number
Radio model
Pc to radio interface?
Radio model
Log4OM: 2.13.0
Omnirig
IC7300
USB
Omnirig
IC7300
USB
Have you unlinked the usb cat from the acc in the 7300 menu?
Did you instal the genuine Icom USB Drivers before connecting the radio to the pc?
Are any other programs running at the same time like wsjt, cwskimmer etc?
By manual changes I mean switching from CW mode to USB-D.G4POP wrote: 19 May 2021, 18:31 Have you unlinked the usb cat from the acc in the 7300 menu?
CI-V USB Port is unlinked from REMOTE.
Drivers, yes. Radio works fine for all modes.
Other programs running, no. I close WSJT-X before changing to CW mode.
Not drivers for the radio, usb drivers for the pc
Please post a screenshot of your device manage showing LPT and com ports
And it only goes off line when you change from CW to USB-D? Not other mode changes?
Try downloading a fresh rig list from Omnirig in case your rig.ini file is corrupt
I pinned down the sequence that forces log4om offline. It's when you unload the 7300's FT8 preset from memory. I did this when I was swapping back and forth between USB-D and CW modes. Happens every time.
I did replace the Omnirig 7300 ini files btw. So, there's no reset function?
No there is no reset function
So you were running WSJT or similar are you running Log4OM, Omnirig and WSJT to 'Run as an administrator'?
