Cluster window only showing 10m
M0TNX
Post by M0TNX »
Hi All.
New user and just feeling my way around.
In the (F8) Cluster window, all I see are spots for 10m. I've set filters for the cluster in VIEW> Cluster View and that works perfectly, how do I see more bands in the main window that shows Cluster/Map, please?
Screenshot attached. Thanks for any help.
Kev
Re: Cluster window only showing 10m
You have locked the padlock at the top of the cluster which locks and synchronised the cluster to the radio band
M0TNX
Post by M0TNX »
Terry.
Thanks as always for the speedy reply, I'd locked the band (on the right) to see only 20m, yet the F8 window (on the left) is showing 10m
I just can't figure how to get the left hand window to display spots other than 10m, I've tried locking and unlocking the padlock on the right several times.
Kev
Click worked you will see all spots in the image you have filtered by LOTW
you may have other filters selected in other filter tabs but I can't see those
M0TNX
Post by M0TNX »
Spot on advice - all sorted - thanks again Terry.
Kev
