Qso Forwarding from hrdeluxe to log4om
Posted: 27 May 2021, 16:46
by IW3GCR
Hello everyone.
Using hrdeluxe only for digital connections, I would like to be able to use the possibility with the udp ports to import with the "qso forwarding" the qso file in log4om, wonderful program, but I can't.
I assume you can't because of the diversity of databases, is that correct?
Thank you
nicola
Re: Qso Forwarding from hrdeluxe to log4om
Posted: 27 May 2021, 17:09
by DF5WW
Don´t think that there´s a problem with the different databases but i think that HRD not have
an option to make an UDP outbound as ADIF_Message. If HRD has the possibility for that it should
work, if not no chance for a forwarding i think.
Posted: 27 May 2021, 19:04
by IW3GCR
Yes DF5WW it's possible...
log_hrd 1.png (44.33 KiB) Viewed 2878 times
but what am I wrong or what I forget..and attention, only the two programs concerned are active, hrd and log4om.
Nicola
Posted: 28 May 2021, 05:00
by DF5WW
Could be possible that HRD send the new Log entry in the N1MM XML format as describet in the Box below
the HRD UDP settings. Log4OM is waiting for standard ADIF data. That´s only my Idea, maybe we have
another guy here which uses HRD for digitals and have it work.
Posted: 28 May 2021, 09:22
by IW3GCR
DF5WW you are completely right !!!
All the best.
Nicola
Posted: 28 May 2021, 14:35
by CT1BXX
Nicola,
Good news :D
Working properly is a good solution for having RTTY in real FSK and not AFSK as FlDigi does.
Maybe at the weekend I will try. :)
