Qso Forwarding from hrdeluxe to log4om
IW3GCR
Post by IW3GCR »
Hello everyone.
Using hrdeluxe only for digital connections, I would like to be able to use the possibility with the udp ports to import with the "qso forwarding" the qso file in log4om, wonderful program, but I can't.
I assume you can't because of the diversity of databases, is that correct?
Thank you
nicola
Nicola IW3GCR
Re: Qso Forwarding from hrdeluxe to log4om
Don´t think that there´s a problem with the different databases but i think that HRD not have
an option to make an UDP outbound as ADIF_Message. If HRD has the possibility for that it should
work, if not no chance for a forwarding i think.
IW3GCR
Post by IW3GCR »
Yes DF5WW it's possible...
log_hrd 1.png (44.33 KiB) Viewed 2872 times
but what am I wrong or what I forget..and attention, only the two programs concerned are active, hrd and log4om.
Nicola
Nicola IW3GCR
Could be possible that HRD send the new Log entry in the N1MM XML format as describet in the Box below
the HRD UDP settings. Log4OM is waiting for standard ADIF data. That´s only my Idea, maybe we have
another guy here which uses HRD for digitals and have it work.
IW3GCR
Post by IW3GCR »
DF5WW you are completely right !!!
All the best.
Nicola
Nicola IW3GCR
CT1BXX
Post by CT1BXX »
Nicola,
Good news :D
Working properly is a good solution for having RTTY in real FSK and not AFSK as FlDigi does.
Maybe at the weekend I will try. :)
73 Manuel Fernando CT1BXX
