contest mode
KB1FGC
contest mode
Post by KB1FGC »
Hi,When I click on Contest mode nothing happens,it only refreshes.I read that it is in the main U.I but I don't see it.
Thanks Rich
73 KB1FGC
Re: contest mode
KB1FGC wrote: 09 Jun 2021, 01:15 Hi,When I click on Contest mode nothing happens,it only refreshes.I read that it is in the main U.I but I don't see it.
Rich,
Look at Page 86 of the most current User Guide.
Did you first select the Contest/contest settings you are wanting to use? Once you do that then the Crown (contest) Icon on the Main UI will light up the related contest fields.
KB1FGC
Re: contest mode
Post by KB1FGC »
Ok Nolan my fault.I skimmed the Manuel thinking it was like the previous version.If I followed the directions it would of worked.
Thanks Rich
73 KB1FGC
