CQ Zone = 0
EI2GLB
CQ Zone = 0
Post by EI2GLB »
Hi All
Just looking through the new version and I noticed that I have over 200 QSO's that are showing the CQ Zone as 0
Is there any automated way I can update these with out having to do each one manually,
Trevor
EI2GLB
Re: CQ Zone = 0
Yes, from QSO Manager, select all QSO the "update info" button.
You can filter for them by using SEARCH PARAMETERS on bottom of the page, setting CQZ [EQUALS] (nothing on right side) and adding the filter.
This will be done using QRZ.COM/HAMQTH, you need to have one of those set in your config.
EI2GLB
Re: CQ Zone = 0
Post by EI2GLB »
Thanks Daniele I update some one by one using the edit QSO option so it's good to know I can do them all at once,
Thanks for the work on this program,
Trevor
EI2GLB
