Hi folks, the award is set to check the 160,80 and 60meter bands. It should be changed into 80,40,20,15 and 10.
Each one can do it manually.
Take care pals
Wrong bands on CHINESE PROVINCES award
Moderator: OE6CLD
73 91 de Daniel
OA9DVK (also IK2SGL)
From somewhere in the Amazon Rainforest
Permanent activity from the Communal Reserve of Chayu Nain, ref. OAFF-0040
Latitude - 5.023231 ( 5 1' 23'' S)
Longitude -78.340072 (78 20' 24'' W)
Re: Wrong bands on CHINESE PROVINCES award
I have asked Claus to check this but meanwhile you can modify the award yourself!
Hi Terry, this is exactly what I did. I have just dropped here a note to suggest to all those who cannot find their references to modify the award.
Thanks anyway for the reply.
73 91 de Daniel
Hi Daniel,
I fixed the bands and removed Inner Mongolia, which is not part of the WAPC Award. >The updated award has been uploaded to the award server.
Hope this helps.
Claus
Hope this helps.
Claus
Claus, OE6CLD/DJ0DX/EI7JZ
Hi Claus, always very efficient.
Thank you for the note and good point for the Inner Mongolia I had not noticed.
Tnx for your great support.
73 91 de Daniel
