Data Lookup causes cursor to jump entry field in WinKeyer Interface?
G0UJA
Post by G0UJA »
So I'm calling CQ on CW and receive a reply at 30wpm, I enter the callsign in the WinKeyer interface and when I look at the screen half the callsign is in the callsign field and the rest is in the CW Text entry box...
This seems to be caused by the data lookup being triggered and is tricky to correct and reply at the same time!
Are there any work arounds - even disabling data lookup sources does not solve this.
Is it possible to prevent any data lookup for say 5 seconds after first character is entered in the callsign field?
73 James G0UJA
Re: Data Lookup causes cursor to jump entry field in WinKeyer Interface?
Yes I can confirm this and we will attend to it ASAP
G0UJA
Post by G0UJA »
Thanks, any chance of coding a CQ repeat timer in the same fix? :P
73 James G0UJA
G0UJA wrote: 12 Jun 2021, 09:50 Thanks, any chance of coding a CQ repeat timer in the same fix? :P
Not immediately, there is a huge difference in the time required to fix a small bug like this to adding a complete new module and we have other priorities at the moment.
It is however on the list
