Hi everyone,
I have been using Log4OM for a while (1.16) and decided to upgrade today to the new release (1.17.1).
For my surprise, my log disappeared and I got a message " MYSQL DB upgrade required 192.168.1.25:3306\k1pll"
Running windows 8.1 64 here.
My MYSQL database is located in another computer (Windows 7 64 )192.168.1.25 port 3306
I have log4OM installed in 4 machines and access this database over the internet without a problem.
Thanks Daniele for this great program.
Luis !!
Re: MYSQL DB upgrade required
Sorry Luis, update script has not be published by Wordpress in my website.
You can find it in the download section now, or here: http://www.pisto.it/LogOm/mysql1171.zip
Run the script in your MySQL database or, if you're unfamiliar with queries, just recreate database and import back your last log.
In case you need previous version to be able to read log to make a backup here you can find the previous release:
http://www.pisto.it/LogOm/Log4OM_1160.zip
or
http://www.pisto.it/LogOm/Log4OM_1160_Portable.zip
Sorry
or
Sorry
Thanks, was waiting for this as well - switched over to SQLite meanwhile for testing.
Claus, OE6CLD/EI7JZ
Claus, OE6CLD/EI7JZ
Claus, OE6CLD/DJ0DX/EI7JZ
Hi everyone.
I have a problem in the Log4Om program when I want to open the .sqlite database telling me that DB update is required. This occurred when closing the database of my LU4FTA callsign and opening that of my other LV1F callsign to load the qsos that I made in the CQ WPX that took place this weekend. When I reopened the LU4FTA database it won't let me open and it gives me the message that I must update DB.
I appreciate your response.
73 by Felipe Stefania LU4FTA / LV1F
Can you create an empty new database and import an ADIF backup file?
