LoTW second certificate
UT4ULP
Post by UT4ULP »
Greetings! I have two valid LoTW certificates, in the settings I installed, in addition to the basic settings, I also filled in "My call (opt)" with the callsign of the second certificate. When sending, I received an error that the callsign of the certificate does not match the callsign for sending. Turning on the log in debug mode, I saw that the cmd launch command does not have a parameter for the callsign (-c Callsign).
Here's what the debug:
Code: Select all
11: 16: 30.996 Debug: [LOTWManagement] [UploadLog]: -d -u -a all -q -x -l "MyLoc" "C:\Users\User\AppData\Roaming\Log4OM2\temp\LOTW_UPLOAD_20210624111630.adi"
Although the launch command was supposed to be:
Code: Select all
-d -u -a all -q -x -c "CallSecondCertificate" -l "MyLoc" "C:\Users\User\AppData\Roaming\Log4OM2\temp\LOTW_UPLOAD_20210624111630.adi"
If you need any additional information or possibly screenshots, please write in addition. Thank you so much!
Re: LoTW second certificate
checking. Thanks
