Hi,I use Norton antivirus and it auto detected a L4ONG.configmanager.exe file.Under that title it said Heur.adumlb.I'm not sure what that means but the program seems to be working.Norton put the file in Quarantine.Do you suggest taking it out of Qurantine?It says it is a high risk.I recognize the file as relating to LO4OM.What do you suggest?
L4ONG alert
Re: L4ONG alert
Its a false positive take it out of quarantineKB1FGC wrote: 10 Jul 2021, 03:00 Hi,I use Norton antivirus and it auto detected a L4ONG.configmanager.exe file.Under that title it said Heur.adumlb.I'm not sure what that means but the program seems to be working.Norton put the file in Quarantine.Do you suggest taking it out of Qurantine?It says it is a high risk.I recognize the file as relating to LO4OM.What do you suggest?
