Winkeyer/Contest mode
HB9ETR
Post by HB9ETR »
Not a biggy but....
the SRx input, if not numerical, does not show in the RECENT QSOs SRx field on the Winkeyer Contest page....ok in the main UI though
ie: the IARU HQ Stations (REF, RSGB, SRS etc) doesn't shown in SRx on Winkeyer page but does in the main UI
Rob
HB9ETR / G0IFL
Win10 i5-11400 @ 2.60GHz
Re: Winkeyer/Contest mode
HB9ETR wrote: 10 Jul 2021, 13:40 Not a biggy but....
Rob,
Check the tic boxes chosen for the Grid Layout in the WK Interface. I did not have mine 'tic'd for display of the SRx column.
Screenshot pleaee
HB9ETR
Post by HB9ETR »
First pic is main UI showing a correctly populated log
Main UI.png (65.49 KiB) Viewed 3683 times
Second pic is WK UI showing no lettered SRx input
Winkeyer UI.png (60.84 KiB) Viewed 3683 times
Third pic is WK UI with a mix of numerical and "lettered" SRx resposes
Winkeyer UI 2.png (67.54 KiB) Viewed 3683 times
Rob
HB9ETR / G0IFL
Nolan,
Please document this on Mantis it's clearly a bug
G4POP wrote: 10 Jul 2021, 19:33 Nolan,
Terry,
Done. Mantis #390
No, it's not a bug.
there are 4 fields, according to ADIF specifications, to save Received and Transmitted exchanges in contest.
sRx, sRxString
sTx, sTxString
the "string" version is always saved, while the non string version (numeric field) is saved only if the string version is a number.
In the specific case i think the user "renamed" SRxString into SRx, as SRx is ONLY numeric and if not set it shows ZERO (0)
